Tarot T810 build with Pixhawk FC
Just started building a Tarot T810 with Pixhawk FC
I've only been using Naza before but decided that the Pixhawk will be a better choice for this hexa.
Here is the parts list so far
  • Tarot T810 folding six-axis rack TL810A
  • Tarot T810/T960 six-axis folding tripod TL96013
  • Tarot T810/T960 mount dual battery under the seat TL96018
  • Tarot T810/T960 gimbal mount kit TL96014
  • 6xT-Motor MT3515 400KV
  • 6xRCTimer SimonK Speed Controller ESC HVSK-40A
  • Foxtech Supreme C/F Propeller(14x4.8) (Supreme 1448)
  • DYS RC Model 300A Power Distribution Board
  • 3DR Pixhawk with u-bloc GPS and compass
  • 3DR Radio Telemetry Kit 433
  • MinimOSD
  • Multistar High Capacity 6S 10000mAh Multi-Rotor Lipo Pack
  • LED Lily Pad (12LEDs RGB)
  • Turnigy Receiver Controlled Switch
  • FrSky 2.4GHz Accst Taranis X9D
I'm documenting the build here http://www.maciej.se/T810.html but will also update in this thread.
Currently the frame and legs are assembled and I hope to be able to start with the electrical part this weekend.
  • Not very much new... have uploaded Arducopter 3.2 to the pixhawk and configured the 6-pos switch so it's working fine now, a calibration and a curve to tune PWM output was needed.
    http://www.maciej.se/T810.html#6pos
    Tarot T810 Build Log
    My Tarot T810 Build Log
  • Calibrated the SimonK ESCs today with the Pixhawk, went quite smoothly, made some test afterwards and there doesn't seem to be ay sync issues :-)
    http://www.maciej.se/T810.html#esc
    • Have connected 3dr Radios and been working on calibration of my new gimbal... Alexmos 32 isn't easy to get working properly.
      http://www.maciej.se/T810.html#gimb1
      • The build continues installed a PDM today and hope to be able to solder all the cables tomorrow.
        http://www.maciej.se/T810.html#pdm
        • Have now soldered the ESCs, power cable and step down modules to the PDM, will just test everything so I don't have any shortages and cover the solders with liquid electrical tape, should finally be able to start to configure the Pixhawk. ArduCopter 3.2 is supposed to be released this weekend so I will go with that version.
          http://www.maciej.se/T810.html#pdm1
          • The power module if finally ready, motors are connected and the Pixhawk is mounted. Now I can start to configure the Pixhawk.
            http://www.maciej.se/T810.html#pdm2
