Hello,
I am trying to get a video link between a TBS Groundstation and a TBS unify.
I set both RX and TX to Channel 8, 2510 Mhz,
For the Groundstation, according to manual, that is dip switch combination 00000001. Unlike the lawmate I think that means dip switches 1-7 up and 8 down when seen from top.
http://www.team-blacksheep.com/tbs-groundstation-manual.pdf
For the Unify, according to manual, channel 8 is 3 black arrows pointing up followed by two red arrows pointing down. :)
http://www.team-blacksheep.com/tbs-unify-manual.pdf
I assumed that the unify color code was
white = audio
yellow = video
Red = +5 V
Black = Ground
I also checked with a lawmate RX-2460 (stock), no signal.
I get the feeling the TBS Unify might be broken.
I have attached pictures of both dip switches and a simple example cabling, any help is greatly appreciated.
Thx
  • facepalm,
    the gopro AV out cable was broken. Small solder platform came right off the circuit board. Didn't expect that to be the problem...
