This is the conector you need to use the defalt uart0 plug on the APM 2.5. At the moment you will have to make the adaptor cable as I dont think there is one avalible yet. This is the conector to fit the APM 2.5 board.
Being that the firmware always uses UART0 unless you change it, find UART0 on the board.
Sorry, I know that's not the exact answer you are looking for, but with any luck, they silkscreened the same names on the new boards, so it shouldn't be hard.
Ted
I see the cable you posted is the correct one, after sending reply I noticed the pic was wrong. Opps
Jack
The cable I posted is listed for hooking up the 3dr to the 2.5, just the picture is wrong. It has a df13 connector on one end.
https://store.diydrones.com/DF13_5_Position_Connector_17_7_cm_p/ca-...
Jack
https://store.diydrones.com/Adapter_cable_for_APM_2_5_p/kt-apm25-ca...
I need one too when my apm 2.5 shows:).
I know where it plugs in, but now it actually takes a plug close to the Ublox....I just don't know what it's called So I can order it.
