I am having issues with connecting my Navio2 Flight Controller to my computer using 3DR FPV radio telemetry modules. As seen in the image below, I have both modules attached and each have green lights - though the one attached to the Navio2 has a red LED that is flashing as well. I am able to recognize the COM port that the USB module is attached to and through Mission Planner I have been able to assign settings to it and its remote counterpart. However, when I try to connect, it fails. The baud rate is the default 57600, and this also doesn't work in QGroundControl. I was following this guide for the Mission Planner steps. I can post more information if needed. Any help would be appreciated!
3691380395?profile=original
  • I've figured the issue out. I was able to try out a second Navio2 out with the same equipment and it worked to perfection. It appears that the issue was the UART port in the original Navio2 - it appears to be slightly damaged from having a wire pulled out of it, and the port was the issue in this problem. Thanks to those who helped in this discussion.
  • I'm not sure what you mean by "modules". I'm on Windows 7, so I suppose the setup would be different there.
    Marc LE BRET said:
    Not easy.
    I have some modules (3DR or equivalent) and Comport is USB Serial Port (FTDI), version 2.12.0.0 26/08/2014, on a W10 setup.
    Dan Beich said:
    I can now confirm it's not a port issue. I tried another computer's ports and I got the exact same errors. I believe I have the right USB to UART driver (v.6.7.6), so that shouldn't be the problem.
    Telemetry Issues - Connecting a Navio2 to Flight Planner using Radio Telemetry
    I am having issues with connecting my Navio2 Flight Controller to my computer using 3DR FPV radio telemetry modules. As seen in the image below, I ha…
  • Not easy.
  • I can now confirm it's not a port issue. I tried another computer's ports and I got the exact same errors. I believe I have the right USB to UART driver (v.6.7.6), so that shouldn't be the problem.
    Dan Beich said:
    Wait, then what would that mean if just the air module was blinking red, and not the ground module?
    Yeah, it definitely might be a bad port. When I try the different USB ports, they all come up in Mission Planner as COM12. I thought that they should have different numbers?
    That's a good point, I'll turn the Wi-Fi connection back on.
    I'm going to try this on another computer to see if the com ports work there.
  • Wait, then what would that mean if just the air module was blinking red, and not the ground module?
    Marc LE BRET said:
    Red blinking is data transmit.
    When the two units are connected (mission planner), the two units have red light blinking. If connection is not established, ground red (near the serial plug) is off.
    It could be a bad COM port selection or Serial 1 speed not at 57600 in the ArduPlane settings.
    If you have wifi on your raspberry, you can have the console UPD TELEM1 activated all time (even if wifi is not connected during flight). It is convenient when working the settings at home, like downloading logs (no way to do that with radio).3702460177?profile=original
  • Red blinking is data transmit.
  • steady green indicate the two units are paired.
    Do you know what the red flashing light means?
    My /etc/default/arduplane file looks like this:
    TELEM2="-C /dev/ttyAMA0"
    ARDUPILOT_OPTS="$TELEM2"
    I already made the Tx/Rx mistake where I connected Tx to Tx and Rx to Rx.
    The red tape on the wires is where I fixed that problem.
    It's a Chinese clone that violated the 3DR trademark. It happens. That doesn't mean it doesn't work, just that it wasn't made or designed by 3DR. Caveat emptor
  • The branding isn't on there, but this is the place on Amazon where it sold.
    Chris Anderson said:
    I don't recognize that radio. Are you sure it's a 3DR?
    Robot Check
  • Steady green indicate the two units are paired.
    Can you look at https://docs.emlid.com/navio2/common/ardupilot/installation-and-run...
    and confirm Telem2 line is uncommented in your arduxx file.
    If there is also a micro usb plug on the air unit, you can use it with Raspberry USB out ( Telem line in config file is /dev/tty/USB0)
    UART out Rx and Tx lines are to go to Tx and Rx plug of the air unit (crossed).
    RMK: do not fly without using the four supplied spacers between Navio card and Raspberry.
    Marc
    Installation and running - Navio2 docs
DIY Robocars via Twitter
RT @DWalmroth: Weather's finally cooperating, looking forward to racing 1:10 scale autonomous cars outdoors again! @diyrobocars, @NVIDIAEm…
Wednesday
RT @AIDRI_: I finally succeeded in optimizing the trajectory and speed of a car on a #racetrack. Next step: implement a 2d controller and…
Wednesday
@jetdillo @circuitlaunch Actually the second *in person* event in a year. We do virtual races every month
Apr 2
Update: we're moving it back one day to Sunday (the 4th) at 11:00am instead
Apr 2
@GrantEMoe @circuitlaunch Update: we're doing it on Sunday (4th) at 11:00am instead
Apr 2
Laurie J. Troy liked Jasper Kueppers's profile
Apr 1
RT @chr1sa: Maybe we should have a mini @DIYRobocars race in our lower school's playground https://t.co/xLFeua1R6X
Mar 29
If anybody wants to join us for an informal outdoors hack/race we're going to be meeting at the @CircuitLaunch park… https://twitter.com/i/web/status/1375907409223249923
Mar 27
RT @SmallpixelCar: Ready to reopen, innovation has to continue. Inside/outside, LiDAR/GPS, race/delivery https://t.co/jpmvttoHEd
Mar 26
DIY Drones via Twitter
RT @DAVGtech: By far best race yet! Congratulations to the winner @Heavy02011 🥇🏆🍾👏👏👏 @diyrobocars @donkey_car @NVIDIAEmbedded https://t.co/…
Mar 20
RT @Heavy02011: #VirtualRaceLeague: @DIYRobocars Race #8 - #ParkingLotNerds ⁦@DAVGtech⁩ ⁦@DWalmroth⁩ ⁦@OttawaAVGroup⁩ - join us tomorrow h…
Mar 20
RT @mrpollo: 11 years ago, the pxIMU was announced to the world on @DIYDrones, and it changed the life of many (mine included). The followi…
Mar 18
RT @ishcahealth: This is awesome! ☘️ @DroneDJ @DIYDrones @WorkerDrones @DroneMedia_UK @dublinaviation https://twitter.com/media_ireland/status/1372077878536462336
Mar 18
RT @DAVGtech: Changing the game, now with a Lidar. All in a virtual environment and free to anyone. #VirtualRacimgLeague @diyrobocars https…
Mar 18
Great video from UCSD students telling their @donkey_car racing story https://www.youtube.com/watch?v=M4uVoQAyt5s
Mar 18
Timothy Miller liked Joseph Udofia's profile
Mar 18
