  • Problem solved by going under
    intitial setup
    3dr radio
    then loading settings with uav powered and telemetry connected
    then I had to fix the "link settings" which did not match my the right settings
    • Same problem here. Mac OSX, everything worked fine with 2.14, but 2.15 won't connect via telemetry. The app hangs...
      Did ou do the above via a USB connection??
