Telemport testing xbee pro s1
I am new to this, and I am trying to set up my xbee pro s1 modules.
I have always obtained mavlink timeout in MP, and in X-CTU range testing I have 'timeout waiting for response'.
However I am sure the modules are paired, as when I connected the APM xbee DI and DO pins together, it returns the data sent to the PC fine. Therefore I have narrowed it down to my 'sketchy' soldering on the Telemport.
I am looking for help writing to the output pin on the telemport and reading it through the input port, to see which one needs fixed.
I have tried re-soldering a few times but I think it may be busted now :( the solder rings are no longer visible, I fear I have ruined the port. I would like to test though before I sort out a new oil pan.
Thanks in advance
    Can you post a picture of the current state of the solder. You maybe able to use another uart port on the APM or is the issue with the XBee breakout board?
  • Forgot to add, the test code returns port 0, but not port 3.
