  • So it turns out that the value that's getting read off is too low. Depending on what kind of BEC I use, I can get values ranging from 2940 on higher. I just have to lower the 3000 value that's being used now to determine if it's connected.
  • This link may help check in the APM code your readings.
    APM Speed sensor issues
    You can test it with a 5 volt source and an analog voltmeter.   You should see the voltage moving if you blow on the pitot tube.
