Thermopile code
Hi, I was just reading through the code, and cant seem to understand the following part in the sensor tab/section
long x_axis(void)// roll
return ((analog1 - 511l) * 9000l) / ir_max;
long y_axis(void)// pitch
return ((analog0 - 511l) * 9000l) / ir_max;
I basically get all of the other stuff about reading the thermopile's
I get that the analoge port reads a value between 1 and 1022 or something, and that 511 would imply horizontal.
But I don't understand where the multiplication of the number 90001 comes from.
I think i understand that the ir_max is for calibration or to make the readings more accurate, but is this by finding the maximum difference between ground and sky? Idealy using the z sensor when angle <10 deg
    ahh, its an L and not a 1 :P Thanks for your replies. So if i am understanding correctly, you use the L at the end of a number to scale it to a long? instead of putting in all the place holders? or am I completely wrong? But to be honest I am not realy an expert in this so I think i may be wrong.
    I have been doing some more studing of the code, and once again don't quite understand this line.
    analog2 = ((float)analogRead(2) * 0.01) + ((float)analog2 * .99);
    why breaking it down into two float values, and not taking the reading from just one analogRead(2) ? I am guessing this is for some accuracy and rounding errors?
    I think if some-one could recommend a good book/ website that I can consult about programming micro controllers it would probably help as I can try work it out on my own instead of asking 100's of questions :P I have been working through all of the arduino.cc help on the site, but it doesnt always go into much detail about these technical things
    Hi Alex,
    That bit had me confused for a while because on my text editor the default font has like 1 pixel difference between l and 1. It can be very easy to confuse 90000l and 90001
    That's actually 9000 Long. 90 for degrees and *100 for accuracy. It's a way of doing integers instead of floats and it's how the output from the 406 GPS comes out.
    The ir_max is the maximum difference, say 200. If we are at 100 then we divide and multiply that times 90 to get 45°. I do it in this order to preserve accuracy in the calculation.
    Floats are great but for Lat and Long they aren't accurate enough on AVRs.
    for example the location -1223811835 is actually -122.3811835, but in AVR world the last two numbers 35 will get rounded off to who knows what. That's almost a 10 meter difference I believe.
