Hi Guys,
i am the new one. I am 28 year old software developer from germany.
I was flying my apm 2.5 for at least 1 year with only some small problems. Because of longer flight time, i've updated my setup from 1000kv 3s 5000mah to 4s 4500mah with sunnysky x3108 900kv.
Since then I have significant problems to adjust the pid values. As soon as i switch in AltHold to run Autotune the Copter jumps up and down very fast. I have spent at least 8 hours of tuning the pids and try to run autotune without real success.
With 9" Props the quad flies okay but if i switch to my desired 10" props i get the described behavior in alt hold.
As Frame is an TBS Discovery (no pro) with stock dji arms.
here some pictures of my problems:
Here you can see the "jumping" since i switch in althold.
I think the problem is my "throttle out", but i dont know why:
As you can see, my Throttle out goes crazy since i switch to althold.
Here are my current PIDs, generated from autotune with 9" props:
Also i think, my barometer is fine:
So, i have no idea where the problem is.
My Quad weights almost 1,7kg, regarding to sunnysky it has 4,4kg lift capacity with full power and 10". I've also tried to change my Hover throttle (to 430) with has no effect. I am using the 3.2rc3 release.
Since I really dont know how to handle this problem, I'd be glad to get help from you.
Thank you very much,
Jacob
Hi Richard,
as you can see, my vibrations look good until i switch into althold mode:
Hi Jacob,
they are fine! so I can´t help you. Good luck.
Juan Antonio
Hi Jacob,
I think you have the same problem that me http://diydrones.com/forum/topics/magfield-affecting-relalt see my disscusion . Can you show me your Realt from the log?
Juan Antonio
Hi Juan,
i think my Realt is also fine?
Jacob
