Hi all,
I've noticed when in AUTO mode and my RC TX is turned off or goes out of range the throttle % drops to considerably low values. i.e. 15%  The plane flies very very slow when this happens (8 m/s).
When RC TX is on or within range in AUTO mode the throttle ranges between 20-30%.  But usually sits 23-26% for level flight.
APM Parameters:
Max throttle =40%
Cruise throttle = 25%
Min throttle = 0%
My question is why does the throttle drop so low when TX is not connected when cruise throttle is 25% Id like to fly longer missions and its better if my TX is not constantly on for hours.  I've disabled RTH fail-safe for TX fail when in AUTO mode.
Thank you in advance.
Jon
  • I'm thinking it is the throttle nudge parameter. THROTTLE_NUDGE.  I will set it to 0.  It must be thinking to reduce throttle because the ch3 value is minimum when TX out of range or off. Will test this soon.
    • This didn't seem to work.
      Any ideas anyone?
