Throttle Input not reading from RC
I recently got my arducopter assembled and all hooked up.  When I go to calibrate my RC through the APM I get readings on everything BUT the throttle.  Not sure why?  I hook up a servo to that input on the receiver and it works just fine?  Any ideas?  Halfway tempted to re-map that input (throttle) to input 8 since I am not using the camera?
Riley
    Ch8 input is a Hardware failsafe so be careful. Try and plug another channel into the CH3 slot. If it doesn't work, try a different receiver. Also, please indicate which receiver you have.
