Tower App Parameters
I am using a Iris+ with the Tower App.
Is there anything that tells what each of the parameters is?
I would like to set a default speed for waypoints instead of setting each waypoint speed individually.
  • There is a default speed option for navigation in the advanced param  page. Right lower corner if I remember right. The value setled there will be assumed for navigation between waypoints unless you set something different on each waypoint.
    • Thanks, I will check it out.
