  • I am not constructing any system yet!
    I try to have the minimum possible questions before starting!I am a bit cautious because i don't know so much about connecting electronic boards etc!I don't want to destroy the items i will buy and throw to garbage my money!
  • I mean the rc transmitter and i am thinking that if i add gps i must add another switch on my rc transmitter..
    am i right??
    Dinos,
    I'm sure you'll get the help you need here, however could you give us a little more to work with? What are you adding the GPS to? What do you think you might need to change, and why? Giving more detail will certainly result in a response to your question. That said, I will assume you are talking about adding a GPS to an Ardupilot or similar. Without any other information I would say that if by "radio controller" you are referring to your RC transmitter, no there isn't anything to change. However if by "radio controller" you mean your Ardupilot or similar, then yes there are definitely things to be changed in the header files. If the latter is the case, post more information about your system, hardware, code version(s) your using, etc. Be as specific and detailed as possible and you'll get the response you need.
    Nathaniel
