Transmitter configuration please help
Hi
I want to synchronize the rc transmitter with arducopter configurator
1. attempt
motors, lipo, esc and usb are all tied (propellers take off) i am opening arducopter Configurator. Cross section of the Transmitter Adjustment. I move rc sticks like configurator says and I can see movement on the screen.When I completed, the new values can not load the arduMega. I got a configuration error like "upload unsuccessful "
2. attempt
at the transmitter
adjustment part, there is a warning on the screen, "the engine and esc power must be disconnect " But when ı am disconnect the lipo arduMega and esc are shutdown because of less power. the usb port of computer not enough to feed ardumega and esc at same time. But arducopter configurator wants it.
3. attempt
I disconnect both lipo and esc. There is only arduMega and receiver connect with usb to computer. And now ı can not see my rc sticks moves on the screen. configurator can get sensor values but can not get rc transmitter values
at least 1. attempt
I can not save control values, but I could see moving
I hope i explain my problem. without solving this problem I can not go forward
please help me
  • Hello,
    2 comments :
    - The 1st time you use your APM on your configurator, don't forget to initialize E²PROM (in the Initial setup menu)
    - don't forget to set your PC Windows "International parameters" to english (US). In fact, the separator has to be the "."
    (in WINDOWS configuration menu)
    After, use should be able to calibrate & save your Tx sticks.
    Good luck,
    Gilles
