Over the last couple of flights I've been getting a reasonably small, but significant oscillation of my yaw when no stick input is provided. It yaws for about a second in either direction. If I input a slight amount of yaw using the stick, it will stop it, but it will return when I release the stick.
What could cause this? It's the wavy lines... Log is also attached.
And zoomed in on the first section:
I'm getting the same issue in my tricopter with 2.7.1. What version are to using? Could you post your PID settings?
Regards
Jose Manuel
