  • Hi,
    you probably want something like a quarter circle rotating 90° with a tiny servo. It should be slightly inside the fuselage. In its closed position (covering the lens) the quarter circle segment should point backwards, in its open position forward. You can use the mode switch AUTO setting to keep it open, any other setting to close it or whatever else works for you.
  • Or, if I could set it up to open only when the pictures are being taken, or set altitude/altitude range?
    • Hi Josh,
      I am currently trying something similar. Have you found a solution already? Curious.
      Thanks a lot.
      Greets,
      Gijs
