Posted by Taylor Thomas on February 8, 2015 at 6:18pm
Hi all,First off I'd like to say how great a resource DIY drones has been for my drone project. I'm in the process of building a fixed wing drone using the FX-61 phantom and Pixhawk.I've modified a Canon A 495 for NIR using the publiclab.org filter kit. I've been experimenting with different camera settings and am ultimately looking to use this modified camera with an intervalometer script using CHDK. I've read some posts on the USB trigger for running a distance based intervalometer script.The problem is... I'm not able to load the proper CHDK firmware from the SD card. I know the version I need, but I can't figure out how to load the firmware. Could anyone on here suggest a good way to proceed?The sd card is 4gb, non bootable, and has been formatted.Any suggestions you can provide would be most appreciated. Thanks a lot in advance!
Put CHDK on the card following instruction, put card into camera, start firmware update procedure and make card bootable.
http://chdk.wikia.com/wiki/CHDK_User_Manual
http://vignette1.wikia.nocookie.net/chdk/images/9/91/CHDK_Installat...
http://chdk.wikia.com/wiki/CHDK_For_Newbies_-_How_To_Install
or use ACID:
http://chdk.wikia.com/wiki/CHDK_quick_install_Guide
Thanks again,
Taylor
