I am trying to run simulink Blocks on Ardupilot Mega 2.5 + . The Arduino IDE is included as part of the target install. The IDE includes a folder of standard files for compiling code. These files had to be modified for the simulink blockset.
The two files are src/io _wrapper.cpp and include/io_wrapper.h in the directory C:/MATLAB/Targets/R2012a/arduino/
For both files i should simply add the line " #if 0 " before the code and add the line " #endif " to the last line of the files.
Whenever i open these files in any C++ editor say in Eclipse or CodeBlocks, I can do nothing. I cannot make any changes. The editor does not accept any keyboard input when i punch letters. However i can navigate using the mouse and all other features like auto-highlighting, suggesting etc. seem to work. I cannot make any changes however.
Does anybody have any idea how to fix this ?
Any luck with this? I'm in exact same location right now but I can't locate those files by any means. I've seen it has a lot to do with using any other version besides Matlab 2012b. I take it you're also trying to use this tool?
http://www.mathworks.com/matlabcentral/fileexchange/39037-apm2-simu...
Someone claimed if you use the Matlab version they used then there should be issues.
