Trying to Odroid XU4 Companion running with pixhawk
Hello,
First if this is posted in the wrong place feel free to redirect me to a better forum.
I've been following this tutorial.  I've got a FTDI cable connected as described (without the +5v connected) and that seems to be working.  I've set the baud rate as described.  When I get to the section to enter the command "mavproxy.py --master=/dev/ttyUSB0 --baudrate 1500000 --aircraft MyCopter" here is what is shown through the terminal:
odroid@odroid:~$ mavproxy.py --master=/dev/ttyUSB0 --baudrate 1500000 --aircraft MyCopter
Connect /dev/ttyUSB0 source_system=255
no script MyCopter/mavinit.scr
Log Directory: MyCopter/logs/2016-01-25/flight6
Telemetry log: MyCopter/logs/2016-01-25/flight6/flight.tlog
MAV> Waiting for heartbeat from /dev/ttyUSB0
fence breach
online system 1
STABILIZE> Mode STABILIZE
APM: PX4v2 002E0027 35324716 36343032
Flight battery 100 percent
Received 377 parameters
Saved 377 parameters to MyCopter/logs/2016-01-25/flight6/mav.parm
Process Process-1:
Traceback (most recent call last):
 File "/usr/lib/python2.7/multiprocessing/process.py", line 258, in _bootstrap
   self.run()
 File "/usr/lib/python2.7/multiprocessing/process.py", line 114, in run
   self._target(*self._args, **self._kwargs)
 File "/usr/local/lib/python2.7/dist-packages/MAVProxy/modules/mavproxy_map/srtm.py", line 128, in createFileListHTTP
   conn.request("GET",self.directory)
 File "/usr/lib/python2.7/httplib.py", line 1052, in request
   self._send_request(method, url, body, headers)
 File "/usr/lib/python2.7/httplib.py", line 1092, in _send_request
   self.endheaders(body)
 File "/usr/lib/python2.7/httplib.py", line 1048, in endheaders
   self._send_output(message_body)
 File "/usr/lib/python2.7/httplib.py", line 892, in _send_output
   self.send(msg)
 File "/usr/lib/python2.7/httplib.py", line 854, in send
   self.connect()
 File "/usr/lib/python2.7/httplib.py", line 831, in connect
   self.timeout, self.source_address)
 File "/usr/lib/python2.7/socket.py", line 557, in create_connection
   for res in getaddrinfo(host, port, 0, SOCK_STREAM):
gaierror: [Errno -3] Temporary failure in name resolution
Could it be that I missed something while installing the packages listed in the tutorial?
Any help would be greatly appreciated!
Loren
  • I connected the Odroid to a network that had internet connectivity today and it worked.  Do I need to have access to the internet for my Odroid to run mavproxy properly?  Or did I misunderstand the DNS issue?
    It's failing to resolve the DNS name to get the terrain data.
    what version of MAVProxy are you using and ArduPilot?
    mavproxy --version
  • Hi Loren, it seems that initially it works well (otherwise you wouldn't get parameters, heartbeat, and mode). Are you running Ubuntu 14.04?
    • Yes I believe so
May 21
Azjeg liked Azjeg's profile
Apr 27
Benewake LiDAR liked Benewake LiDAR's profile
Apr 12
Gremsy liked Gremsy's profile
Mar 12
