Tunigy 9x Firmware with Mavlink stack
Hello,
I release a new firmware for Turnigy 9x,
You can use telemetry from APM (watching battery voltage and GPS informations).
You can tune major value of PID (not all).
And the last you can change flight mod via Mavlink or PPM chanel.
Actually I tested only on the last version of AduCopter, I thing you can easily change the sources code to adapt for ArduPlane
Project home :
http://code.google.com/p/gv9x/
 Download binary :
http://code.google.com/p/gv9x/downloads/list
Turnigy 9x with Mavlink from GerardV on Vimeo.
Main screen with alternate voltage display (transmitter and APM)
On the picture, '20.1' is the voltage of APM and 'STAB' is the flight mod
3690890779?profile=original
Mavlink infos screen
3690890630?profile=original
Mavlink GPS screen
3690890807?profile=original
PID settings screen (can modify P & I parameters)
3690890677?profile=original
Settings flight mod cmd
3690890860?profile=original
I had two another parameters :
alarm on low battery from mavlink and the setting of the baud rate (it is preferable to get an high speed RF module)3690890902?profile=original
  • Who says we don't have an uplink?  Couldn't we use the raw data encoded into a PPM channel to send data to the APM?  It would require "translation" code in the APM firmware to accomplish this, but I'm seeing the bigger picture...
    • 9x with FrSky could be a standalone setup with PID tuning & save waypoint capability using your firmware.
    • Add bluetooth on the 9x, and then design smartphone GCS station.
    • USB connection (or bluetooth as above) from 9x (Smartieparts board?) to laptop in the field, for on the fly updates.
    • PC-based PPM encoder to FrSky directly.  You could then fly exclusively via joystick and not need a TX at all.  This capability exists already, just with the more expensive Xbee link.
  •  If you never flash this radio you can find all documentations on er9x project found here :
    modding your radio and flashing
    http://code.google.com/p/er9x/
    or you can find a Solderless Pogo board
    for flashing I would recommanded to install eepe :
    http://code.google.com/p/eepe/
    For the transmission you'll need a wireless RS232 high speed datalink, you can use xbee
    but in europe I cannot use 900Mz and you mus modfify like for FRSKY project
    http://code.google.com/p/gruvin9x/wiki/FlashGuide
    My radio:
    3692278971?profile=original
    Due to the ATMEGA64 we approach the maximum memory,and in my version of gv9x-mavlink I remove the splashscreen,
    the helicopter option (all mixing is done in ArduCopter)
    and displays statistics
    the binary is here :
    Next time, I have to explain how to set the rotary switch.
    Tell me if you have problems.
  • like wise is there some info on modding the radio please as i think its great
  • How would you install this? Would you need xbee installed into the 9x?
