Hi all,
There is now several month that i try to optimize the tuning of a big octo-quad (carboncore cortex).
Carboncore use mn4010 motors and tmotor carbon 15" on the top, 16"on the bottom. This set up is working well with DJI Naza, but i never had a perfect attitude with my pixhawk. It constantly overshoot and begin to wobble, worse in loiter mode.
These lasts month i used smaller cheaper (less stiff) props, and it was acceptable (with a low P, High I and D). Now i wants to put the big props and start over. I got back to default PID's and tried with 20.000maH battery.
The setup is 8kgs. I was trying to adjust P with ch6 knob method. On this first flight, i had the feeling that somebody put my sticks (i'm french, and i feel that it will sound funny in english), as the copter made some movement on roll/pitch and yaw, all alone.
Finally, the copter falled on a side as was trying to land it...  4 props to the trash (160€...)
-Could i try an autotune with that kind of setup? anyone has experience with it?
-Generally, what kind of PID's should be applied on heavy copters
-Could anyone analyse the log, i checked all but i didn't find anything. Maybe mag or imu problem?
Thanks for your help!
2015-06-03 16-29-48.log.gpx
  • Hi everybody,
    I'm very happy these days because i solved all my olds problems, and closed 1 year of tunning!!
    First of all, i have to say that the cortex is a wonderful copter, well designed and with an unbeatable stiffness for a folding octo. I never regrets my bought and would buy another if mine would be lost.
    However, I think that the Carboncore's setup can't work (MN4010 370Kv with Tmotor 15" on the top and 16" on the bottom). The power consumption is really low, but the stability is a shame, because props are spinning really slowly, specially the 16". The loiter was a nightmare, constantly overshooting, really scary for a 8kg X8 with a nice camera under it!! Even the yaw was unconsistant, with suddenly changes of heading.
    On my Cortex, the only hardware that is different from Carboncore's one is the esc's. I have rctimer opto 45A, they use tmotor ones. this is the last question i could have to explain that the "official" set up never works for me. I can't figure that the autopilot can be in cause, as they all works on the same principle (carbon core works with Dji and I with Apm, then pixhawk).
    I mounted my pixhawk on dampers (i'll post some pics), and had really good results with vibration, the problem was'nt here.
    Finally, i always had vibrations issues on my shots, with a Sony alpha 6000 (tried with an without steadyshot, worse with steadyshot...) and perfectly balanced props.
    here are my solutions:
    -Same motors but Tmotor 14" on the top, 15" on the bottom. I could believe i changed my copter. after a bit of tuning, I had the most stable machine i've seen, and the trust came back!!  The consumption is a bit higher, but acceptable.
    -10 000mAh battery. 9 minutes of flight time is enough for what i need, video recording. 20 000 works well anyway, but i rather a lighter machine for more agility (i often have to fly close to building and structures, as i'm specialised in building-industry filming)
    -I bought a new pancake lens for my alpha6000, without steadyshot, and vibrations were significantly reduced.
    -I changed the configuration of my gimbal, a DYS eagle eye. It was using compression dampers, and i tried to hang the gimbal to the dampers instead. Vibrations disappear...
    Last thing, if you wants to buy a cortex with a arducopter setup, i would recommend a pixhack. The "sandwich" frame is not so wide in heigth, and you could do without an external damping system
    Feel free to contact me if you are a cortex owner, I would be pleased to discuss about it.
    Julien
Gremsy liked Gremsy's profile
Mar 12
DIY Robocars via Twitter
Nov 27, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 20, 2022
Nov 20, 2022
Nov 8, 2022
Nov 8, 2022
Oct 23, 2022
Oct 23, 2022
Oct 23, 2022
Oct 19, 2022
Oct 18, 2022
Oct 13, 2022
