I assembled APMega into a EasyStar.
Its early days with the programming but radio test code works - i.e. supplies different values as sticks moved.
The Turnigy ESC beeps alot (mainly a 1Hz beep-beep-beep constant). This beep is constant except when the servos are moving (presumably test code running)
Q's are
1) is the ESC properly armed/initiated with this beeping
2) is there some way of getting rid of annoying beeps?
Thanks in advance.
Brett G
