Two-stage voltage alert for battery voltage failsafe
This is a feature request:
On the A2 flight controller, there is a two level battery voltage warning. At the first threshold, the status LED turns yellow simply to indicate to the pilot that the voltage is low. At a second threshold, the status LED turns red and a failsafe (either RTL or Land) is engaged.
This is super useful when you are flying without telemetry, but you still want to keep track of your batteries.
I would love to see a similar feature for APM! Especially because I'm guessing it would be relatively simple to implement. If i had a few more hours in the day, I would learn enough to code it myself, but you know how these things go... :/
  • As-is , nobody really sees the status LEDs while flying, at least not daytime.
    Why should the autopilot have multiple alert levels,while it only *needs* one, the one that is actually an action, like RTL, land.
    Other warnings are really something that belong to a GCS , I too, would like to see APM Planner have a configured voltage , like:
    if Batt_voltage < (FS_BATT_VOLTAGE-(FS_BATT_VOLTAGE/10))   {we are only 10% from failsafe voltage}
    That could be a neat warning to have.
    On the other hand, you can have the transmitter to give a visual and audible warning at different levels, and flash LEDs with an device like this: http://madhacker.org/mavlink-to-hott-adapter/
    The point is, the AP itself does not need another battery voltage warning, but the GCS, or telemetry solution, or onboard LED controller must do something clever with information at-hand.
