UAV link range extension
Dear All,
 I have designed a helical antenna to extend the range of UAV wireless link, now i am thinking to write a research paper on it, which i have achieved. The gain of that antenna is 17 dB, please all of u tell me that should i proceed with this idea or not? is it good or bad?
 Regards
  • I notice that you really like to remain vague, and not give any information which would "lock down" your answers (and thus subject them to public scrutiny). This will be the last post I'm making in this thread, for obvious reasons. Antenna losses of the type we're talking about can be quantified using the Polarization Loss Factor (PLF). Since you did not state what type of antenna (wavelength and design) you are using on the UAV, I'm unable to complete the formula. Suffice it to say that you are experiencing at least 3 dB loss from polarization issues alone, which is the equivalent of cutting your transmit power in half.
    What you term "efficient results" is what I call "lack of understanding of antenna theory."
  • One note of curiosity... since you're using a helical antenna at the ground station end, and since helical antennas come in either LHCP (left-hand circular polarization) or RHCP (right-hand circular polarization) depending on which direction their helix is wound... and since you're not using a helical antenna on the UAV... how are you mitigating the losses from receiving and transmitting with different (or no) polarizations (since both ends of the link must use the same polarization)?
  • Helical antennas were invented in the 1940's by John Kraus (W8JK). Is there anything substantially different in your design that makes it stand out when compared to the standard helical antennas that have been developed over the years (see this link)? If not, perhaps you should consider publishing a construction article rather than a research paper. Since you don't really seem to be very forthcoming in your responses, I'll assume you have not yet discovered something that violates the laws of physics.
  • UAV wireless links can take place on several different bands; which band are you referring to, in particular? Also, as you already know, the UAV as well as the ground station requires an antenna; which are you referring to, in particular? To obtain 17 dBm gain at 900MHz would require an antenna a bit larger than most FunJets can carry. One final thing... what testing methodology did you use in order to determine that your particular design provides 17dBm gain? Do you have a diagram showing the major and minor gain lobes, from both the vertical and horizontal planes? If not, how are you able to make this claim?
  • Are you talking about an antenna for the xbee communication modules?
