Hi All,
I have the UBOX GPS for the APM 2.6 I purchased from banggood.com
When I plugged the connector on the GPS side, the 6-pin block broke.
After pounding my fist against the table several time, I realized the other two connectors on the right, share the same signals; therefore, there is a chance I can add 2x 4-pin connectors, replacing the 6-pin.
My question is, what's the name of those 4-pin connectors? I was told (in RCGROUPS) the connector is DF13, however, the connector on the UBOX LEA -6H board is narrower and keyed. It is similar to the DF13 series, but definitely, not the same.
Any ideas where to get those connectors/cables?
All the suppliers selling cables for these GPS offer the 6-pin connector in one end and two connectors in the other end (2-pin and 4-pin)
Thank you in advance for your help.
Gustyk
Here is a closer look.
https://www.dropbox.com/sc/httcauliowc1l8v/AAB-A7XEzc499HPUPRjLiQhZa
It is JST SH connector at 1.0mm pitch
Did you damage the pads on the board when the connector broke off? Why not just re-solder the connector to the board? I know it's small, but it is possible. I know because I broke a connector off my ArduIMU+ V2 board a few years back.
Re-soldered the connector and bingo, back in service.
Nathaniel ~KD2DEY
Hi Nataniel, Yes. I tried that but the connector dragged the tin pads off the PCB board. Thanks anyways!
Richard, congratulations! You got an A+ in irony. and D- in adding value to this thread.
The (pricing) reasons for selecting one or other vendor are going beyond the scope of this forum. Thank you for your understanding.
Happy new year,
