Ublox-GPS
Hi,Is this normal?When booting up in CLI mode (slider towards servo connections), I ran a test of the GPS. Result is the attached image.After a while it shows the correct coordinates.I assumed it would display 0.0000, 0.000 until getting GPS lock.Anyone else gets these results ?tks,Wolfgangp.s.today switching to AUTO made my plane go to full throttle (the throttle_max = 60% i programmed) aiming at the sky without following the programmed route. Since the mission was correct, I suspect GPS problems. (maybe a loose connection I couldnt find yet)
  • Yes this is normal, you should see it on u-center, it's kinda neat as jumps around the globe... it first finds the hemisphere, then it finds you... you should be seeing the APM red light flashing during this time
