Has anyone had this happen to them? I was doing a few bench tests and I wanted to use my GPS with u-center, so I carefully pried on the connector and........Uh-Oh! I was quite surprised and dismayed. I'm not sure if I'm up to the task of soldering these pads....looks like about .050" spacing...I don't think I have a tip that small.
Ah well patience
I was trying to solder a wire onto the 328 chip for my sonar sensor and I heated the crystal can.
Well the metal can came off....but the REAL bad part was the crystal came undone from the holder !
I thought what the heck, it's not running anyway, so I tried to re solder the crystal element to the gold ends inside the can !
What LUCK. It worked !
Now I'm thinking of hot glue to hold everything but I don't want to push my luck!
Here is the yucky pics.
BTW, the sonar wire works good.
Earl
The best thing about organic core is that it is water wash up and self cleaning. No need to use flux or harsh chemicals to prep your work. It does smell a bit like horse manure.
I use a toothpick to apply a small drop of medium super glue on each side to secure shell to PCB. I also have bent pins over inside this connector, I straitened them out with 00 tweezers. I now take a second and align connectors carefully before seating. If plug does not seat well, check for a bent pin, usually 1 or 6. I have plugged / unplugged these connectors a couple hundred time now, testing IMU and several APs & GPSs
Yes, the same thing happened to me. It may be a bad batch.
If you don't feel up to fixing it, would you like to sell it?
- Don
