I am trying to change the default airspeed cruise from the default 10ms to 15ms.
I followed the instructions in the AdvancedConfig section of the manual. This is what I pasted into my APM_Cofig.h file. (see copy of the saved APM-Config.h below)
#define AIRSPEED_SENSOR ENABLED
#define AIRSPEED_CRUISE 15
#define AIRSPEED_RATIO 1.9936
The new code compiles and uploads to the board. I saved the changes and restarted the apm and arduino. However, from what I can see there have been no changes made. When I use the SHOW cmnd in the CLI the default values remain, same result if I use Show Settings tab in the APM Planner terminal view.
What I am I doing wrong?
Joe
READ THIS. REALLY! READ THIS.
First, you MUST uncomment the GPS PROTOCOL line below or the code will not compile.
This is because we need you to tell the code which GPS module you're using, so we can load the right libraries.
Second, there is a lot more you can do with configuration options is you want. See the APM manual for all the available options.
//-------------- REQUIRED ------------------
#define GPS_PROTOCOL GPS_PROTOCOL_UBLOX // You must uncommment this line by removing the slashes ("//") in front of the "#" and select either the default (GPS_PROTOCOL_MTK) or one of the following other supported GPS modules if you're using one of them instead:
// Other allowed options include:
// GPS_PROTOCOL_NONE No GPS attached
// GPS_PROTOCOL_IMU X-Plane interface or ArduPilot IMU.
// GPS_PROTOCOL_MTK MediaTek-based GPS.
// GPS_PROTOCOL_UBLOX UBLOX GPS
// GPS_PROTOCOL_SIRF SiRF-based GPS in Binary mode. NOT TESTED
//----------------OPTIONAL-------------------
#define GCS_PROTOCOL GCS_PROTOCOL_LEGACY
// The GCS_PROTOCOL option determines which (if any) ground control station
// protocol will be used. Must be one of:
// GCS_PROTOCOL_NONE No GCS output
// GCS_PROTOCOL_STANDARD standard APM protocol
// GCS_PROTOCOL_SPECIAL special test protocol (?)
// GCS_PROTOCOL_LEGACY legacy ArduPilot protocol
// GCS_PROTOCOL_XPLANE HIL simulation ground station
// GCS_PROTOCOL_IMU ArdiPilot IMU output
// GCS_PROTOCOL_JASON Jason's special secret GCS protocol
#define GCS_PORT 0
// This determines which port APM will send telemetery on. The USB port is Port 0, for when you're testing on the ground. The Xbee port is Port 3, for the field and in the air and you want to send telemetery wirelessly
//#define SERIAL0_BAUD 115200
//#define SERIAL3_BAUD 57600
// These determine the baudrate for the telemetry port. Default is 115200bps for Port 3.
// Are you using an airspeed sensor? Choose DISABLED if not.
