unable to load command DO_SET_ROI
ive just updated to AC2.6 and therefore started using APM planner MAV 1.0
ive been working recently with the DO_SET_ROI command (only Yaw_mode 3 currently supported by AC - i mean to get all the modes working), and have come across an error when trying to write a mission containg this command to APM:
Requested value 'DO_SET_ROI' was not found.
at ArdupilotMega.GCSViews.FlightPlanner.saveWPs(Object sender, ProgressWorkerEventArgs e)
at ArdupilotMega.Controls.ProgressReporterDialogue.RunBackgroundOperation(Object o)
in AC2.5.5 this worked, i have simply added the command to mavcmd.xml, as its in the documentation i think it should really be standard:
<DO_SET_ROI>
<P1>Yaw_mode</P1>
<P2>WP ROI #</P2>
<P3></P3>
<P4></P4>
<X>Lat</X>
<Y>Long</Y>
<Z>Alt</Z>
</DO_SET_ROI>
and .. now that im on the subject ..
when creating a mission with a DO_SET_ROI command, once focus is lost from the command its made invisible in the map view.  at least for yaw_mode = 3, which actually specifies a location to point at i think the command should stay visible on the map.  obviously its not part of the route so it shouldnt really appear as a waypoint on the planned route, but a marker just like the waypoints in a different colour would be great.
any chance of looking into these points?
regards,
james
