voltage adjust
hi all, after been using my APM2 board configured as a Quad-X configuration for a couple of days, i decided to add the voltage/current board that i´ve purchased from sparkfun and conected it as stated in the instructions in the Wiki area, selection was made (voltage only) inside the planner but i can´t get the correct voltage, alway show 10,8v while the battery is 11,6v.
My question is, is there any way to adjust the voltage ( inside the Planner ), measured from the batteries ?  thanks
  • yes, it seems to me that it could be a problem with the voltage/current sensor board, in my opinion the planner should include some kind of adjustment setting to help people to adjust correctly the readings... perhaps they will do that in a near future, i hope so,...just my 2 cents.
     thanks
  • When you say "always 10.8" do you mean that it doesn't matter what the battery condition is you always read 10.8? If so, then there is a problem with the sensor or the connections.
    If, however, it does react to the battery voltage but just isn`t very accurate, then measure the voltage on the - and + rails of the sensor input connectors - should be around 5V. Subtract 0.3V from that reading and enter it into the "ÀPM Input Voltage" box on the Battery Monitor tab of the Configuration page. If it is still a little off make small adjustments to the same value, but I find that the 0.3V is normally about right.
DIY Robocars via Twitter
RT @a1k0n: Sync'd @joshu's GoPro w/ my datalogging; video is 2.5X speed, Google imagery upper-right. Found out my track boundaries are WAY…
yesterday
RT @a1k0n: Also, at 45mph, the front tires literally blow up like a balloon and it doesn't have much front traction, so the car becomes fai…
yesterday
RT @a1k0n: Okay, some datalogs! Green dots are precalculated racing line (from my crummy optimizer -- it veers to the middle after 2 for Re…
yesterday
RT @a1k0n: Welp my @selfracingcars entry, hastily conceived heading filter and all, actually worked! Heading home, datalogs and videos to f…
yesterday
yesterday
Friday
RT @f1tenth: What can we learn from autonomous racing? Actually, a lot! To get an idea what you can do in this field and where the research…
Oct 11
Oct 11
RT @a1k0n: It's aliiiiiive! Less than a week until @selfracingcars and I'm just now digging this bad boy out. Been a crazy few months. Hope…
Oct 10
RT @OttawaAVGroup: Mark your calendars. CAV Canada is happening on Dec. 2nd, 10am-4pm EST. And guess what - admission is FREE! Get your ti…
Oct 6
RT @f1tenth: Our new 1:10 scale 3D racetrack is here. We will implement it in the @SVLSimulator in the next weeks so everybody can use it.…
Oct 6
RT @DAVGtech: Received sweet autonomous Ferrari's that we plan to demo at the @IndyAChallenge on our portable @donkey_car track. Let us kno…
Oct 6
Sep 30
Sep 9
RT @chr1sa: We've got another virtual @DIYRobocars race tomorrow at 9:00am PT. Two dozen autonomous cars will compete, four at a time. Ther…
Sep 4
Sep 1
