Hi
I am new to Drones and RC Helicopters
i need an Affordable Drone or RC Helicopter featuring....
1. Live camera or FPV or even a cheap video sys
2. some payload - 1kg to 5kg
3. more than 20 minutes flight time
4. at least 500meters to 1 km control range
5. must be affordable -BUDGET : $1500 to $3000
6. must be NON WI-FI
can be a octocopter/helicopter....... dosent matter as long as it have enough Payload
Please Help
This is something we developed, and offering now, if you want something allot smaller than typical offerings...
Small compact, powerful, and custom options to for H8 Configuration
http://diydrones.com/profiles/blogs/digi-dna-providing-arducopter-b...
Hi Sardar Jee.
We are closer and we can talk.
If you need help, talk to me.
Tipu.Pendoo@gmail.com
There are plenty of mutli-rotors that can lift 1KG that are available for less than $3K
I just finished building a Foxtech FPV Kraken. It can easily lift 5KG. Had it flying for 22 minutes on two 10,000ma 6S batteries with a pixhawk. After adding gimbal and other electronics, it was more than $3K, but for just the airframe and flight controller, you can squeak by at about $3k for one of those. (Gimbal and Battery aren't included in the $3K)
Kraken 130 from FoxtechFPV
hello,
did you find a craft that meets your needs if not I am able to help you put together a nice craft. where are you located?
Cybercrash, I like the idea of building a good quad with gimbal, FPV, and GPS/autopilot features, but in adding up the cost of all the components for a DIY rig, they come out to almost the same, if not more, than a Walkera X350 Pro. Am I off base, or can you really achieve cost savings with a DIY approach?
Thanks much!
Max
Thanks for the info. I like the SK450; as a kit it is semi-DIY. As for GPS/autopilot, I'm most interested in waypoint programming and flying. Would that be an addition to the SK450 you pointed to, or would waypoint feature be a substitute for some components in the SK450 kit? Thanks again!
Max
Go get whatever you want to carry, weigh it, and report the grams here, maybe someone can help you.
If you keep posting 1-5kg, I doubt you'll get much interest. Even if you do post the same message a dozen times.
Oh, and do you understand this is *diy* drones?
