Waypoint Pixhawk Arduino
im trying to send to the Pixhawk new waypoint with arduino nano.Im using this code source:
//include the mavlink library
#include "mavlink.h"
//Baudrate
#define bRate 115200
void setup() {
Serial.begin(bRate);
void loop() {
command_heartbeat();
command_waypoint();
* @brief Sends a heartbeat message every second.
* @param NONE
* @return void
void command_heartbeat() {
//< ID 1 for this system
int sysid = 1;
//< The component sending the message.
int compid = MAV_COMP_ID_MISSIONPLANNER;
// Define the system type, in this case ground control station
uint8_t system_type = MAV_TYPE_GCS;
uint8_t autopilot_type = MAV_AUTOPILOT_INVALID;
uint8_t system_mode = 0;
uint32_t custom_mode = 0;
uint8_t system_state = 0;
// Initialize the required buffers
mavlink_message_t msg;
uint8_t buf[MAVLINK_MAX_PACKET_LEN];
// Pack the message
mavlink_msg_heartbeat_pack(sysid,compid, &msg, system_type, autopilot_type, system_mode, custom_mode, system_state);
// Copy the message to the send buffer
uint16_t len = mavlink_msg_to_send_buffer(buf, &msg);
// Send the message
delay(1000);
Serial.write(buf, len);
* @brief Sends a waypoint command
* @param NONE
* @return void
void command_waypoint() {
//TARGET DRONE
uint8_t _target_system = 1; // Target drone id
uint8_t _target_component = 0; // Target component, 0 = all
uint16_t seq = 0; // Sequence is always set to 0
uint8_t frame = MAV_FRAME_GLOBAL; // Set target frame to global default
uint16_t command = MAV_CMD_NAV_WAYPOINT; // Specific command for PX4
uint8_t current = 2; // Guided mode waypoint
uint8_t autocontinue = 0; // Always 0
float param1 = 0; // Loiter time
float param2 = 1; // Acceptable range from target - radius in meters
float param3 = 0; // Pass through waypoint
float param4 = 0; // Desired yaw angle
float x = 52.464217; // Latitude - degrees
float y = -1.280222; // Longitude - degrees
float z = 200; // Altitude - meters
// Pack the message
mavlink_msg_mission_item_pack(1,1, &msg, _target_system, _target_component, seq, frame, command, current, autocontinue, param1, param2, param3, param4, x, y, z);
// Send the message (.write sends as bytes)
delay(1000);
But it don't work. In mission planer there is no new Waypoint added.
