RT @gclue_akira: レースまであと3日。今回のコースは激ムズかも。あと一歩
#jetracer https://t.co/GKcEjImQ3t
RT @chr1sa: The next @DIYRobocars autonomous car race at @circuitlaunch will be on Sat, Dec 10.
Thrills, spills and a Brazilian BBQ. Fun…
RT @araffin2: 🏎️
After hours of video editing, I'm happy to share a best of my Twitch videos on learning to race with RL.
Each part is…
Hi Melvin,
You can send commands in an Auto mission by using the camera commands:
http://ardupilot.org/copter/docs/common-camera-control-and-auto-mis...
Particularly, you should use DO_SET_CAM_TRIGG_DIST or DO_DIGICAM_CONTROL depending on your application. Again, I haven't tested it, but you should be able to send these commands with dronekit according to this guide:
http://python.dronekit.io/guide/auto_mode.html
Hope it helps!
Javier
I got one more question, could you point me to somewhere regarding camera control via dronekit if possible? I read something about gimbal control but nothing around camera triggers.
Thanks,
-Melvin
Hi Melvin,
Check this guide and the source code in the bottom of that page. There is some code to execute some actions based on the waypoint the drone is currently heading to. You could store the next_waypoint in a variable and as soon as it changes, it means the waypoint has been reached.
Alternatively, you could try to add a listener for this variable (vehicle.commands.next), though I'm not sure it works, you have to test it first.
Observing parameter changes
Best,
Javier
As it did help quite a lot in part, see im trying to make the drone stop at the waypoint so it can execute a script from its computer companion. In order to do that in code i need something to tell me it reached it so it can execute. Think of it as if(waypoint_reached: Execute script.
Any ideas if that's possible?
You could add a delay of 3 to 5 s in the command:
http://python.dronekit.io/automodule.html#dronekit.Command
Hope it helps!
Javier
