Hi All,
Everything work fine, but after updating to the last version I've this error writing waypoint:
Error: System.Exception: Timeout on read - setParam
in ArdupilotMega.MAVLink.setParam(String paramname, Single value)
in ArdupilotMega.CGSViews.FlightPlanner.<BUT_write_Click>b_70
If I use the version 1.0.34 I can write WP without any problem.
If I use HK I can write WP without any problem.
Reading WP does not give any error.
Any Ideas?
BYE!
  • Thanks a lot Michael.
    bye!
  • ok!
    Thanks a lot.
    Don't worry about it--it's just a cosmetic bug that will be fixed in the next version. As you'll see if you read the waypoints, they are recorded. You can also use HK GCS if the message bothers you.
