What downward camera angle for FPV?
Couldn't find any info on this topic. Sorry if it's a dup.
I've just started flying FPV on my quadcopter, at first I had a 5 degree angle but found it was hard to see the ground coming up when decending. I turned the camera down to 15 degrees with much more success.
Can people give me an idea of thier conclusions on FPV camera angle? Pros and cons?
Thanks,
A.V.
  • When I fly FPV, especial classic heli or multi quad, I do takeoff and land with direct view (from behind view).
    Usually I put my FPV glasses little bit lower than normal, in order to be able to see the model directly.
    Once I have enough safe altitude, 3m, I do look only to the glass monitor. I never combine direct view with FPV view because you can easy be disoriented.
    When I fly FPV my glider, I do have enough time to put/remove FPV glasses when it time to takeoff or land.
