  • Sigh, nevermind, it's still inconsistently arming different esc's at power up.  Throttle trim at lowest and re-calibrating doesn't seem to have an effect.
    So, the search for a solution to this problem is still on.
  • Oh jeez, it was as simple as re-calibrating.  Thanks Arashi.   I'm going to close this thread since it is pointless now.
  • Thanks for the reply, that's good to hear that you've been able to get yours to work. I had originally calibrated the esc's separately.  I'll try the calibration and put the throttle trim down also.
  • I use the same ESC's.  I have to go through the normal ESC throttle calibration, then I have to scroll the throttle trim all the way down to actually get the quad to arm.
