I have the 2014 Quad X Frame you show in the picture and in the default configuration it only supports 11" props. There are two ways you can build the frame, "default" as shown on the 3dr.com/learn website or with swept back rear arms. The new kit includes additional holes in the frame for this configuration though I can't find any documentation regarding this setup. I want to use 12" props myself so I'm going to configure it this way. I don't know yet if this requires you to configure the frame type as "V" in mission planner but I'll report back once I find out.
Just a follow up. By using the alternate mounting holes on the rear legs the frame will accommodate 12" props. 14" props wont work as there is only 2 inches of space between the front and rear props. I configured my setup as a "V" type frame in Mission Planner and so far it flies with out issue.
Yes this version of the 3DR quad has mounting holes for a gimbal but you'll need an adapter plate. The only place I've been able to find it is here;
http://www.unmannedtechshop.co.uk/tarot-t-2d-gimbal-adapter-plate-k...
This works perfectly with the Tarot 2d Gimbal that I already had.
I started putting the quad together and can confirm the 3DR Quad Frame accommodates 14 inch props.
I also noticed there is a new version of the frame, 3DR Quad D Frame Kit.
http://store.3drobotics.com/products/3dr-quad-frame-kit
