  • You can not use 6S. They are rated for 4S only.
    http://www.helipal.com/tl68p02-4006-620kv-brushless-motor.html
    30A ESC should be fine with 4S.
    Rekhy Zakaria Pasaribu said:
    Hi peter, im sorry for late respond.
    Very helpful description, thanks.
    But i have more question about your description, Can i use 6s lippo battery for this motor? And what esc you recomend for this motor? I apreciate your answer, thank you.
    Tarot 4006 High Power Brushless Motor (620kv)
    This is a medium size motor optimized for Tarot 1355 propeller and 4S LiPo, light weight and efficient for 650 to 700 size multi-rotors, generating 6…
  • Hi peter, im sorry for late respond.
  • This is from Tarot:
    This is 4S (14.8V) motor, specially designed for FY650~FY690 frames. Able to use with 11" to 13" propellers. In our testing Fy680 Pro, we used this motor, carrying GoPro, Brushless Gimbal and FPV system (all up weight 2.7kg), with 1355 propellers and 4S 5500mah battery, we've got 14 minutes of quality flight time, we recommend this motor if you are using 4S battery packs.
    Peter
