Attached is communication recently received from Transport Canada with respect to the SFOC requirements for UAV operators.
From: Civil Aviation Communications Centre - Centre de communications de l'Aviation civile [mailto:services@tc.gc.ca]
Sent: Thursday, September 12, 2013 8:12 AM
To: Calvin Reich
Subject: UAV / SFOC
Good day Mr. Calvin Reich,
Thank you for your recent e-mail received in the Transport Canada Civil Aviation Communications Centre.
In consultation with one of our specialists, I am pleased to provide you with the following information:
In order to respond to your e-mail, we will provide you with some general background on UAVs and then answer your specific question.
Unmanned aircraft are “aircraft” under the Aeronautics Act and are governed by the Canadian Aviation Regulations (CARs).  The CARs define UAVs as:
Unmanned Air Vehicle - means a power-driven aircraft, other than a model aircraft, that is designed to fly without a human operator on board.
UAVs are aircraft of any size that may be remotely controlled or may have an automated flight capability, used privately or commercially or both.  In order to operate a UAV in Canadian airspace, UAV operators require a Special Flight Operations Certificate (SFOC).  SFOC's are issued to both individuals (the pilot) and companies/organizations (i.e. UAV Operators).
A model aircraft is defined in subsection 101.01(1) of the CARs as: “an aircraft, the total weight of which does not exceed 35 kg (77.2 pounds) that is mechanically driven or launched into flight for recreational purposes and that is not designed to carry persons or other living creatures”.
To be considered a “model aircraft”, all three conditions must be met:
        (i)     the aircraft must weigh 35 kg. (77.2 lbs) or less,
        (ii)    the aircraft is mechanically driven or launched into flight for recreational purposes, and
        (iii)   the aircraft are not designed to carry persons or other living creatures.
Under the Canadian Aviation Regulations, an aircraft that has no pilot on board which is over 35 Kg is not considered a model aircraft regardless of whether or not it is used for recreational purposes.  Similarly, an aircraft which has a maximum take-off weight less than 35 Kg used for purposes other than recreation is not considered a model aircraft.  In other words, when a model aircraft ceases to meet the definition of a model aircraft it becomes an unmanned aircraft and is subject to the standards of safety that govern unmanned air vehicles.  Model aircraft may resemble small unmanned air vehicles at first glance; however, on closer inspection the distinctions are considerable.
While model aircraft do not need a SFOC, they are limited in their operation (e.g. operated by sporting enthusiasts for recreational purposes and personal enjoyment, not for monetary gain or any other form of hire and reward). Recreational use of aircraft does not include use of aircraft where there is any payment, consideration, gratuity or benefit, directly or indirectly charged, demanded, received or collected by any person for such use. Examples of non-recreational use include, but are not limited to: research and development flights, flight training, flight testing, customer demonstrations, academic purposes (e.g. student competitions), border and maritime patrol, search and rescue, fishery protection, forest fire detection, natural disaster monitoring, contamination measurement, road traffic surveillance, power and pipeline inspection, scientific missions, earth observation, communication relays and imaging purposes such as aerial photography.
To answer your specific question in the case provided, the UAV operator would need an SFOC to operate the UAV whether they are conducting test flights or conducting a commercial activity.  Like manned aircraft, as soon as they leave the ground, they are subject to regulations. Doing test fights after maintenance actions on a manned aircraft would be equivalent to doing test flights on a UAV.  In both cases, the pilot/operator is not exempt from the regulations that govern the aircraft/operation.  While the legal mechanism to authorize UAV flights in Canada is presently an SFOC, in future, pilots will need to be licensed, the aircraft will be marked and registered, the operators will require an operating certificate, the aircraft will hold a flight authority and will meet a design standard.  The Certificate holder in question will need to inform the Transport Canada Inspector that they need an SFOC that is valid for the period of time that covers not only the “photo shoot” but all other flights as well.
I trust that the foregoing has addressed your questions. Should you need other information on civil aviation matters, please feel free to contact us via email at services@tc.gc.ca or toll free at 1-800-305-2059 (Option 7).
Again, thank you for writing.
Kind regards,
Dyanne B.
Program Information Officer /Agente d'information sur les programmes
Civil Aviation Secretariat/ Secrétariat de l'aviation civile
Transport Canada Civil Aviation Communications Centre/
Centre de communications de l’Aviation civile, Transports Canada
1 800 305-2059
Facsimile / Télécopieur 613-957-4208
services@tc.gc.ca
TTY / ATS (613) 990-4500
Place de Ville (AARCB), Ottawa ON K1A 0N5
http://www.tc.gc.ca/eng/air-menu.htm
Government of Canada / Gouvernement du Canada
- Please consider the environment before printing this email
               - Devez-vous vraiment imprimer ce courriel ?
-----Original Message-----
Sent: September 10, 2013 7:14 PM
To: WEB Feedback
Subject: UAV / SFOC
Comments: Hello,
I am an insurance broker that provides coverage for a number UAV pilots and operators.
There is a question that has come up on a number of occaissions.  Perhaps you could let me know Transport Canada's stance on the following:
Many of the smaller UAV operators are doing Video or photography work.  The SFOC applied for is often specific to a particular photo shoot.  If the operator does a test flight prior to the photo shoot and does not collect any revenue is the flight considered "commercial"?  Often operators will want to try their equipment before the shoot to make sure everything is set up and good to go before they proceed with the shoot.  It may be the day or the week before the shoot, and it gives them a chance to make any fine tuning adjustments before the actual SFOC authorized photo shoot.  Would these "test" flights be considered legal?
I pose the question as most insurance policies will cover the insured as long as they are operating legally.
Would you be able to clarify when the UAV is considered to be operating commercially.
I look forward to your response.  Should you have any questions do not hesitate to contact me.
Calvin Reich
UAV / Aviation Insurance
Capri Insurance Services Ltd
creich@capri.ca
Title: UAV / Aviation Insurance broker
Organization: Capri Insurance Services Ltd
Telephone: 1-877-272-2774
Province or territory: British Columbia
  • So does this mean that it's illegal to fly a drone for commercial reasons without a SFOC? You can't tell me that all those UAV service providers (photo/video) get a SFOC everytime a client needs a project done?
    Thx
    • Carlos- According to the rules set out by Transport Canada, any UAV operated for reward or hire a SFOC is required.
      http://www.tc.gc.ca/eng/civilaviation/standards/general-recavi-brochures-uav-2270.htm
      According to the regulations it is illegal to fly for commercial purposes without an SFOC and the operators can be subject to a fine.  Are there operators operating without an SFOC? I expect there are a number of them and I expect some will continue to push the envelope until there is an incident and more enforcement of the current rules.  According to Transport Canada any operation outside of recreational use requires a SFOC. There are also a growing number of operators that are playing by the rules.  Some operators have a blanket SFOC that will allow them to do various flights, others are taking out SFOC for each project.  More and more people are becoming aware of the rules and regulations and it will likely be a matter of time before those without the proper documentation will find it harder to get work.
      • Carlos,  There definitely is a blanket or open SFOC.  I know a number of operators that have them.  It is usually only issued after you have spent a fair bit of time submitting for a per flight SFOC.  Once Transport Canada is comfortable with the operations and know the operator is operating in a safe manor and knows the rules they will consider the Blanket SFOC.  A separate SFOC is required for each region of Transport Canada.  The blanket SFOC will be for a set time and may need to be renewed but will cover more than one flight.  Each situation is a little bit different, the onus really falls on the operator to prove to Transport Canada that they are operating in a safe manor in accordance of the laws.
        Some operators have also got blanket SFOCs for a specific practice area.
        • ah! Just read this Calvin! Thank you.
          Do you guys have any guidance or suggestions for this special "professional" letter I need to submit for Transport Canada? I'm making my goal tonight for bedtime reading to go through the entire section on their website!!
          • Carlos,
            If you send me an email at creich@capri.ca I have SFOC checklist that I can send you.  It is quite useful in putting the SFOC application together.  Keep in mind the process is likely to change down the road but this is the process at this time.
    • To operate legally yes, SFOC needed for every flight, or an open blanket SFOC, which is what we have.
      • I actually chatted with Transport Canada today and they said there is no such thing as a blanket SFOC... Every flight needed an SFOC. Can you point me to the site you were able to get this SFOC?
        • http://www.tc.gc.ca/eng/civilaviation/opssvs/managementservices-ref...
          It's referred to officially as "long-term authority".
          We talked with our regional TC reps to determine how and when we were able to get it.
        • It is basically an SFOC with an extended date range and area of operation.  Ours covers all of Atlantic Canada until the end of the year.
          • Got it... Just spoke with Transport Canada again. They confirmed this. It sounds like after requesting a few SFOC's they will assess if a blanket SFOC is required. Were you offered one or did you request for one?
            Also, the lady mentioned a change in regulations that will be a lot "tighter" for commercial UAV's... Any word on these or what they will all be about?
