  • I guess if it is rigid and light enough any material would be fine. I've seen frames in quite a few different materials.
    Good luck in your search! If you flew liek me you'd just order the ton from China :)
    Regards
    D
  • Tom,
    Been having a search and really struggling find anywhere that goes below 0.75 inch! This place doesn't have it but boy do they have a lot of stuff in, maybe worth an email?
    http://www.sss-steel.com/public/pdf/SSS_Steel_Reference_Book.pdf
    Also, have you tried your local model shop(s) as they might stock the smaller stuff?
  • Hmmmm,
    Must be lost in translation :)  Unfotunately Google is proving pretty insistent that I buy local (it keeps reverting me to UK companies!) but have a look at this place, if they don't have it maybe they can get it?
    http://titanium-stainless-steel.continentalsteel.com/viewitems/alum...?
    I'll keep searching....
    Aluminum Rectangular Tubing
    Browse Aluminum Rectangular Tubing in the Continental Steel & Tube Co. catalog including Item #,Size,Working Decimal Equivalent,Estimated Weight,Esti…
  • Hi,
    Im in the UK, but searching for 12mm 0.5mm aluminium tubing produces loads of results! I had no trouble in sourcing here.
    For example this was the first result I clicked on which contains 0.5, 1 and 1.5mm wall thickness:
    http://www.tubesupplies.co.uk/upload/stocklist.pdf
    Try tube instead of profile!
May 21
Azjeg liked Azjeg's profile
Apr 27
Benewake LiDAR liked Benewake LiDAR's profile
Apr 12
Gremsy liked Gremsy's profile
Mar 12
