Hi!
I am in the process of ordering a XL-maxbotic MB1260 (http://store.diydrones.com/MB1260_XL_MaxSonar_EZL0_p/ac-0004-16.htm) sonar but is advised by Jdrones staff that the MB1200 (http://store.diydrones.com/MB1200_XL_MaxSonar_EZ0_p/ac-0004-15.htm) is the recommended standard.
Anybody have any suggestions if proceeding with the MB1260 will cause incompatibility or any other possible problems when ported with the arducopter? Is this similar to deciding to get an APM1280 or an APM2560.
Thanks.
Flight 1. The MB1200 worked well as I tried previously with 2.0.37. Altitude hold worked well at all altitudes and the data was very clean. There were a few drop outs as the quad got up near 700 cms but alt hold held together.
Flight 2. The MB1260 with doubled samples (for VCC/1024/2 scaling) did not fly as well. Alt hold did hold but there was some weird jumps at 6 ft altitude. At lower altitudes the sonar worked as well as the MB1200. At higher altitudes where it was mixing with baro, it wasn't holding very well. I looked at the data and there was sonar noise at the higher altitudes. I wouldn't call the MB1260 a clean replacement with scaling added. The reported altitude values did line up with the baro altitude indicating that the scaling seemed get the right output values.
I'll try later today just flying the MB1260 without the doubling of the sample values (stock 2.0.36) and see how it does. However right now I'll switch back to the MB1200 after my next couple of experiments.
Heino
