Dear Sirs,
i down load the source code QGroundControl2.8.0 and want to build in Qtcreator5.5 platform, but the result show me as following:
Project ERROR: MAVLink folder does not exist at 'libs/mavlink/include/mavlink/v1.0'! Run 'git submodule init && git submodule update' on the command line.
Cannot read E:/Worldwide_Quadrotor/PIXHAWK/Software_Code_Framework/(code)QGroundControl/qgroundcontrol-2.8.0(1)/qgroundcontrol-2.8.0/user_config.pri: No such file or directory.
pls tell me where and how to excutive the command 'git submodule init && git submodule update'? i conduct this order in Git shell command line enviroment.but obtain the following result:
and the second problem is that how could i get the file named user_config.pri?
thanks for all kindly assistance .
Obtaining source code
Source code for QGroundControl is kept on GitHub: https://github.com/mavlink/qgroundcontrol.
Each time you pull new source to your repository you should run
git submodule updateto get the latest submodules as well. Since QGroundControl uses submodules, using the zip file for source download will not work. You must use git.thanks for your instruction!
yes ,i do as your mentioed above step by step,
i get source code by installing git, and pull down the code;
and i install the qt and qt creator5.5.1 which show in the website page with this address ;
and intall Visual Studio 2013 cmpiler from the indicated this address.
and so i think my build enviroment is Windows: Desktop Qt 5.5.1 MSVC2013 32bit, then Launch Qt Creator and open the
qgroundcontrol.proproject.but, the compiling result is show as following:
i check the build&run option and see the compiler in qt version, compiler, and kits option page.
so i check some frum and find someone said that need install compiler MinGW4.9.2, so i down load and unzip
under the qt installer directary. but the question is same again and the hint is not changed.
i dont know how to setup properly in the qt build&run configuration with MSVC2013 compiler, and need deeply instruction in compiling QGroundControl.
thanks for all assistance sincerely
Your "Kit" for Visual Studio Compiler is not set up correctly in QtCreator. Some googling on QtCreator Visual Studio Kit should point you in the right direction.
