Will this Prop and Motor work with this Battery?
Props:http://www.hobbyking.com/hobbyking/store/__25819__10x4_5_SF_Props_2pc_Standard_Rotation_2_pc_RH_Rotation_Blue_.html
Motor: http://www.hobbyking.com/hobbyking/store/__18225__Turnigy_D3530_14_1100KV_Brushless_Outrunner_Motor.html
Battery:http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=18633
Thanks! Im using a 30AMP ESC
  • Are ou using these on a quadcopter, and if so, what frame? The prop may be too small for the motor, I'd go with these props, usally the bigger the prop, the less the effeciency, but your motor is powerful. The 10x4.5 will work though, just at a high RPM. If your going with the more powerful motors because you need to lift a heavy rig, I would get a more powerful battery. Like Dan said, you should be fine though because of the battery size, depending on your aircraft.
  • At a glance, it seems reasonable to me - but I still have limited experience with these things.
    My reasoning is this:  I currently have 10x4.7 props, 850kv motors, a 4S lipo, and 20A ESCs.  You have chosen higher kv motors, but a lower voltage battery - by approximately the same proportions.  That means you should have similar RPM (and thrust) at a similar throttle setting, but you will draw more current.  You have 30A ESCs, so that shouldn't be a problem.
    If I am mistaken in my logic, hopefully someone else will chime in as well.
