MR60
World Record for Duration of Flight
3689563453?profile=original
1 hour 20 minutes
- APM 2.5 takes the world record for Multi-Copter Duration of Flight powered by a rechargeable battery. [note:  records also exist for hover that can occur indoors and take advantage of ground affect]
Flight Requirements:
- Distance > 1 kilometer
- Minimum elevation from ground the greater of 2 meters or two prop diameters (no ground affect)
- Lands within 50 meters of Launch
- Minimum of two way points > 0.25 km apart
- Altitude Climbs: Two climbs > 100 meters each
- Ends before voltage drops below recommended minimum level for recharging
- Flight over ground that does not vary more than + 20 meters in elevation
Actual Flight
- Distance: 1 - 2 km
- Min elevation 2 meters
- Ended at start
- Three way points with two 0.3 km apart
- Two climbs:  126 meters and 112 meters
- 13.06 volts left with 10 volt recommended minimum
- Ground + 10 meters
Time:  > 1hr and 20 minutes (81.43 minutes)
Multi-copter:
- Octa 2XQuad 6Up+2Dn (wanted to fly something novel that would show off the flexibility of APM 2.5)
- 3.18 kg AUW
- Li-Ion battery
Attached are the flight logs.  Later I'll provide:
o Video
o Earthview of flight
o Altitude gains
o Details of the copter (design and weights)
2013-11-26 11-41 187.kmz
2013-11-26 11-41 187.log
2013-11-26 11-41 187.log.gpx
  • Congratulations on your record!
    Although, unless I am mistaken - this flight was done way before you and in quite cold weather:
    http://diydrones.com/profiles/blogs/qadrocopter-125-min-in-the-air?...
    2 hours and 7 minutes.
    I am not sure if it was official or not, but 2 hours is a bit better than one.
    Cheers,
    Mark
  • MR60
    Other questions,
    How did you fly this beast 100m high up in stabilize mode, because at such altitude you can't see your ship anymore?
    I notice you used the honeycomb laminate material to build your APM pod. How did you fix the board on it, with what vibration isolation if any?
  • MR60
    Hi Forrest,
    This is amazing! Bravo!
    I am glad you pursued your efforts, although some jealousy and frustrations from some people tried to discourage you, to make something real and impressive!
    Why did you choose this tiger motor instead of the MN3510? Lighter ?
  • Good work Forrest.
  • Hi Forrest,
    Great accomplishment, novel design and very careful choice of components really produced a serious endurance copter.
    I would actually think any piloting inadequacies only add to your accomplishment, hard enough to maintain adequate concentration for that long a flight.
    Clearly the Panasonic's (and low enough power requirements for hover and flight to accommodate them) are still the way to go for records.
    But your unusual frame layout proved it had genuine flight capabilities.
    And I am sure it would turn in impressive flight times even with a conventional LiPoly and a camera.
    Why did you go with 15" DJI props instead of T-motor, actual test or couldn't get the T motor props?
    Best regards,
    Gary
    Astounding! Huge congrats. Can you compile all the stuff in this thread and turn it into a single blog post, which will appear on the front page of the site? It deserves the attention!
  • MR60
    Finally broke the video into three parts.  The videos are compiled from 2754 time-stamped Canon stills taken every 2 seconds.  At a video rate of 20Hz, the videos are 40x actual speed.  Sometimes the copter goes outside the FOV of the camera (had to trade between showing detail and scene area).  The white box that is the most visible part of the copter is the thermal blanket on the battery.  If you lose track of the copter, watch where I am and the copter is usually 5 to 120 meters up.
    Stage 0:  Shows the flight prep and takeoff location about 1/3rd the way between the mancave and way point 2.
    Stage 1:  The octa
    - is launched
    - brought to the man-cave viewing window
    - sent north on it's first slow 120 meter climb reaching the apex about .3km away
    - reaches the second way point (near the lone fir tree at the end of the field)
    - turn SE over the orchard fan towards way point three
    - turns SW back towards the mancave
    http://youtu.be/5chgMCEKtfY
    Stage 2:  The octa
    - shows at the man-cave
    - pauses near the launch site
    - returns to way point 2
    - returns to way point 3
    - heads back to the man-cave
    http://youtu.be/F7WMr7-1fek
    Stage 3: The octa
    - shows back at the man-cave
    - begins second 100+ meter climb
    - returns to launch
    - lands
    - return copter to mancave
    http://youtu.be/fnXL8mOsCW0
    Suggestions would be appreciated on a camera system that:
    - works for 2 hours at -5C without needing a battery change
    - can take 2 hours of video without needing a card change
    - can produce a video that can be condensed and shared
    - can be worn on your head
  • MR60
    This is the elevation chart from the flight log showing the two +100 meter elevation climbs.
    3689563435?profile=original
    and converted to excel
    3689563466?profile=original
    As you can see, I'm not a very good pilot.  A lot of waste and lack of elevation control.  Later I'll experiment with altitude hold (this flight was, except for a few seconds, flown entirely in stabilize mode).
    This is the earth view of the flight.  This is the top view.  It's an important perspective for understanding the video.  The man-cave is the right building where I brought the copter up to the 2.5 floor window where the camera was located.  The camera is pointed north from the man-cave to the turn-around point of the second way point (upper left of the photo).  The photo is rotated so north is from the man-cave to the second way point (going lower right to upper left in the photo).
    3692889507?profile=original
    This is a side profile of the flight.
    3689563339?profile=original
    I'm working on the video now.  I've tried two compiles and both ran out of memory.  If need be, I'll publish the 2754 photos (less than a gig versus over a gig for a video).
    So far, I'm very dissatisfied with the video process.  To film something this long, I used a canon shooting at 0.5 Hz with a super good lens.  But it wasn't adequate.  The objects are too small.  The field of view trying to cover half a kilometer by 130 meters high is too wide.  I need to rethink how these events are documented.  Maybe the only way is a device that can go for two hours or more and be carried around with you on a helmet (or have a friend film it) without running out of juice or memory. Suggestions would be greatly appreciated.  What camera can go for 2 hours in the cold?  What camera can film for 2 hours and not run out of memory? How can you process a file that large?  How do you share a file this large?  If the flight was stationary around the window of the man-cave, it would have been fine, but that's not what flight is about.  So suggestions please.
  • Is this really a world record?
  • Nice!. Did you use "standard" octa config?
    I use crossed sticks underneath style quads, and different prop levels don't matter at all ;-)
    Next solar power addition (summer)
