MR60
Worlds Best ESC - Making it Better
That's a bold statement ... Worlds Best. But it's even larger than that. Not just Worlds Best, but best for most all applications less than 30 Amps (limit of the tests). That means:
- duration ships that only pull 2 to 8 amps per rotor
- most all 6S and smaller ships (exception of nano-ships)
- any-size FPV racer
- any other ship in between
Why almost any size? Shouldn't a small FPV racer use a smaller and lighter ESC for response? Yes, if it does better on a net-lift response test. In other words, when you penalize the ESC for it's weight, is it still better and faster? What i continue to see is ESC manufacturers downsizing critical components of the ESC at a net loss. They weight savings is lost because of greater thrust loss and response. In other words, this heavier ESC will out accelerate, in the real world, a smaller and lighter ESC.
Why post this? To move technology forward, we need to report to industry what works and what doesn't. For some reason (i don't know why), this ESC works better than all others tested:
- for generating maximum thrust from the motor***
- for net-lift efficiency or the grams of weight it can lift (after it lifts the rotor) per watt
- for response (how fast it can generate targeted lift)
These tests were conducted on multiple days on multiple rotors of highly variant size, always being immediately compared back to another DYS 40A multicopter test to ensure that the baseline wasn't changing.
The ESC that dominated is a DYS 40A OPTO Multicopter using SimonK. The photo is included because there are two others that carry a similar or same name.
- Not the white cover DYS BLHeli 40A
- Not the one that is says "Programmable" versus "Multicopter" in the blue/purple band across the front
3691280727?profile=original
Have i tested all ESCs? No, but if you are convinced you know of one that would work better, let me know. I've tested most all of the following and one or more of their variants:
- DYS
- Multistar
- Turnigy
- T-Motor
- Afro
- Motortron
- Quattro
- 3DR
- Spider
- KDE
- ZLW
- Aris
- EMAX
- AutoQuad
- Exceed
- HobbyWing
- Lumenier
To do a test like this, a highly repeatable and finite test stand is needed. It took a while to develop one but what works is one that:
- measures (at a minimum) volts, amps, thrust, motor temp (shoots IR up the aft end of the motor)
- eliminates harmonics between the rotor and load sensor (this proved difficult but achievable)
- is calibrated and proves repeatable within 1.5%
- controlled by a system that can precisely repeat a rotor test (uses a Audurino Mega)
- directly feeds the data into Excel for analysis (uses DATAQ)
- uses a test script that produces repeatable results
- uses a test procedure that minimizes repeatability error (used average of multiple tests)
How much better is this ESC?  On average:
- 4.4% higher net lift (after it lifts itself)
- 2.3% more net-lift efficient (usually the larger the better)
- from more than twice the response or the same response as other ESCs (usually the larger the better)
                                                       So how to make it better?
Step 1: Strip it naked. See photo below.
           ... remove the cover
           ... remove the heat plate (better to locate the ESC under prop wash to run cooler, see below)
3691280569?profile=original
Step 2: Right-Size the bullet connectors or wires (see above where heavy wires are replaced by 2mm bullets)
           ... remove the large bullet connectors or wires
           ... replace them with ones that are the most net-lift efficient (where heat loss = weight loss)
Step 3: Seal the ESC. Seal it with Electrical Sealant to protect from moisture and conductive dust
           ... tape or plug connectors and wires
           ... repeatedly spray each side from different angles
           ... a mistake i made was not sealing the bullet connectors and solder
               - don't tape them off like i did
               - insert a male connector into the end of bullets so sealant doesn't get inside them
3691280655?profile=original
Step 4: Locate ESCs under Prop Wash. See photos below. The turbulence generated by the prop does not adversely affect lift when the ESC is placed on edge to the prop wash.
           ... Use something non-conductive like hot glue to bond the ESCs to the motor mast or spar
           ... Face the FETS (the little square warehouses or Fire Emitting Transistors) to open air
           ... Protect the ESCs from below from ground contact (not needed here because of clearance)
back-side with hot glue
3691280584?profile=original
front-side with FETs completely exposed to open prop wash
3691280749?profile=original
Step 5: Tie up wiring. Use dental floss to secure wiring away from the prop.
***Note: The T-motor Air 40 in high-timing mode (an option) generated higher thrust, but at the sacrifice of efficiency and motor temp. Also, the T-Motor Air 40 was 2nd best and close in performance. If you are using an Air40, it probably isn't worth switching.
  • MR60
    I totally support hard data arguments with open published reproductible measurements, without any "elite club" mentality (the typical : "if you're a real racer you have to use this brand/model ESC, otherwise you're so 2008").
    Forrest is doing science with measurements. A scientific approach means the results can be checked and reproduced by peers. I can't check or reproduce what a FPV/racing guru says about his favorite ESC (and probably saying it because he's sponsored by the maker of that ESC)
    If we stick to a scientific approach, so far DYS40A seems indeed to be the best ESC out there according to Forrest's measured data and that will remain until some other scientific data show another ESC to be more efficient.
    • MR60
      Thanks Hugues.
      Also a confession. Given the seriousness of this topic for FPV racers and manufacturers, i'm in the process of taking a different approach to measuring response, to ensure that the data is correct. If i can measure it using two different approaches and get the same result, then ...
      But, i have to admit, this effort at perfecting the response numbers is a bit silly on my part. Any FPV racer that thinks he/she can respond faster than 10Hz (let alone 300Hz) is focusing on the wrong thing. Focus on removing weight that doesn't hurt acceleration or frame stiffness. A 35 gram weight loss on a 350 gram 250 racer is a 10% improvement in acceleration. Use the best ESC, but more importantly, start shaving weight. Use true carbon, not the fake stuff used on flat plate FPV racers.
      • How you distinguish true carbon and fake? I listened that I have to sand, if black is carbon if it's grey it's fake; is there another method?
        • MR60
          Great question for the King trying to figure out how much gold is in the goblet.
          "Fake" carbon usually suffers from one or more of the following:
          - has a high epoxy content (large impact on strength to weight)
          - dyed glass (moderate impact on strength to weight)
          - advertised as woven or fabric but is twill coated extruded carbon (less durable)
          - not enough resin (too fragile)
          I buy from trusted aerospace sources and perform a "hammer" test on a short piece (while wearing eye protection ... carbon splinters are not nice).
          • Thank's Forrest, aerospace here mmm.....
            some pieces I bought in China looks heavier than others to be CF, I thought that something like you explain was happening.
    • Sure... it's a GREAT ESC for AP tuna boats. It's just NOT a RACE ESC. It's not equipped with the basic features necessary to be a RACE ESC.
      Get BLHeli with MultiShot or at least OneShot125 on it. Get some Active Braking on it. Put it on a diet; get it down to a stripped weight in the 5-8 gram range.
      THEN it will be a RACE ESC.
      mnem
      I am more than the sum of my voltage drops.
      • MR60
        LOL ... and that perfectly summarizes why it's so easy to custom build a 250 Racer that can beat Paul's ship by 30% in a head to head race.
        Paul - Think about what you just said. An ESC has electrons going through it's gates, responsible for the acceleration of your motors. Serious stuff. If you make the gate lighter, by necessity the gate becomes smaller. That is the problem with the above mentioned ESC that completely failed the response test.
        • Sure... in a DRAG race.
          Not in anything else, that any actual RACERS care about. And we have 40A ESCs that will eat these ALIVE because they start with short buses, 4oz copper pour, 16 ga power leads and they STILL have 4KHz refresh AND Active Braking.
          You're trying to distill a race ESC down to a SINGLE factor... single, straight-line acceleration.
          REAL racing is about handling; and unless you've been living in a cave for the last year and a half, if you REALLY race, you know that you need active braking to achieve that, and you NEED faster refresh than 10 or even 500 freaking Hz. *Derisive snort*
          It doesn't MATTER How fast YOUR reflexes are. The faster the refresh, and the faster your ESCs can STOP the props as well as ACCELERATE, the more "Locked-in" your quad is. Why? Because it's not YOUR reflexes that matter. It's the reflexes of the FC, and how they translate YOUR INPUT into actual corrections in attitude.
          Seriously; you have no idea. What you dismiss as "marketing faff" is actual different, better, smarter, faster and stronger technology.
          True race ESCs are all being made from the latest generation, FASTEST, LOWEST IR FETs available with dedicated high-speed driver ICs to reduce overlap that causes desync. They are NOT made by kludging together yesterday's generation FETs in parallel to lower overall IR. :rolleyes:
          You seem to think I'm an ignorant racer; I'm not. ;) I have design knowledge of my own.
          Cheers!
          mnem
          Fuel.
          • MR60
            I can tell you have never drag raced before.
            It's fun. Try it with your friends and stand back and away from any spectators because ... the best description i can think of is ... fireworks. This is how it works.
            - start from the ground with props running
            - on go, go to full throttle
            - attempt to do a controlled take-off at full throttle
            - then transition into forward flight while still at full throttle
            - control the direction and end up between cones (or trees) about 50 meters out that are about 10 meters apart
            Do that, and then tell me you still believe what you just wrote above. I'm all grins because this will shock you and make you laugh at the same time. But be forewarned. It takes time for the Adrenalin to wear off and time for your sudden attack of humility to sink in as you laugh at yourself and your friends. I was foolish enough to volunteer for being at the finish line to judge who won. Never do that again!
            • I raced BMX then MX, then Can-Am, I've bracket raced street stock IRL, raced Sportsman class irl, and raced 1/10 scale AA class and dirt Oval WoO.
              I know more than a little about adrenaline junkie-ing dumping massive current in a few seconds. ;)
              THIS is what I think is fun NOW; all the adrenaline, but it lasts for minutes, not seconds.
              https://www.youtube.com/watch?v=_JY9c5Wzrg0
              http://qz.com/638661/a-teenager-just-won-drone-racings-biggest-ever...
              https://www.youtube.com/watch?v=XB7V3Sckbd0
              https://www.youtube.com/watch?v=lQuEgVNAQhE
              https://www.youtube.com/watch?v=aP0URD6wV04
              I can only dream of being this good some day; but I'm not going to stop trying.
              Right now, this style of racing is the fasted growing, best monetized aspect of model aviation. It is well on its way to being the next X-Games.
              Seriously.
              For THIS kind of racing, or ANY kind of Acro Proximity FPV flight, you NEED faster, stronger, smarter ESCs than the ones you're working with.
              If you look at the latest stuff that's out there, you'll see that we don't NEED huge ESCs with oodles of stacked FETs to drop the overall IR; modern FETs have 1/10th the on-resistance of the FETs in that old design. Added to that, they have a fast enough processor that they can actually turn the ungodly high E-RPMs modern 14-18 pole motors need to max out on small, high-pitch props to OR to pull bigger props on 4S-6S.
              RS2K is the guy who made OneShot125 happen, and he's the guy writing MultiShot. He's one of those FFF adrenaline junkies; he loves 6S and 6045s. I think he's nucking futs; it's all I can do to keep 4S and 5045s in the air. ;)
              https://www.youtube.com/user/cruisecho
              Cheers,
              Paul
