I purchased the recommended Xbee modules and USB adapter board. I also downloaded Digi's X-CTU utility. However, when i run the utility, the utility communicates with the Xbee properly, but it does not recognize the modem type. it says "unknown." That being said, it does have firmware version 1002. I know this from the PC Settings tab and Test/Query button. When i go to the modem communications tab and hit the read button, i get an error that says, "The Modem configuration file was not found. Would you like to check the website for updates?" I do that, but it says there are no updates available. I have also tried to get things working by pressing the Download New Versions Button...it says no new versions are available.
I must be doing something wrong...can anyone help?
Thanks,
Jay
