Xbee and Ardupilot
I have a problem connecting the pc (ground station) with the ardupilot using xbee. i have two xbees (XBP24-Z7) 2.4GHZ
what i exactly do is:
1- configure each xbee on x-ctu to communicate with each other with a baudrate of 57600. one is configured as coordinater AT and the other as a Router AT
2- i disconnect the router and connect it to the Ardupilot using the telemetery cable. the source of power that the ardupilot get is only from the battery.
3- i open the x-ctu on the pc where the coordinator is connected and do test/Quiry test then i open mission planner choose the com port where the xbee is connected and choose baudrate 57600.
4- i then press connect and the process fails.
i would really appreciate it if anyone can help me find a solution to this problem or help me know what i do wrong.
Thanks in advance
karim,
  • yes i have the same problem , and i cant solve it too
