Where can i get the connector on the end of the ftdi cable? I would like to have a cable with this connector on both ends which would connect the xbee to the APM without using 4 separate wires(instead i want 1 4 conductor wire). This will make things less messy, and easy plugins. I checked the diydrones store and sparkfun with no luck.
The xbee will be approximately 30 inches from the APM.
Thanks,
Joel
