For some reason when connecting to the APM channel 4 (rudder) using a Y-harness for a dual rudder setup, there is extreme twitching in one rudder. Has anyone experienced this? Any suggestions?
Does either servo twitch by itself?
If you plug the aileron y cable into channel 4 will it still twitch?
Have you tried 2 different servos on that y cable?
Have you tried a different y cable?
If each servo is independently connected to the APM then they work fine. It is only when using the Y-harness and it is just one rudder. I have tried another y-harness with no luck, as well I have tried another receiver.
Tried that, but same situation.
