  • thanks Michael and Richard it resolved after changing PIT/CV values on Turnigy 9X transmitter
  • Hi Santosh, open up the Initial Settings > Mandatory > Radio Calibration pane within Mission Planner and check that the throttle movement matches the barometer, it should go from the bottom to top. If in doubt hit Calibrate Radio and go through the motion of setting the limits for each radio channel. If this issue persists reply back with the transmitter and equipment you are using.
